[GRASSLIST:439] Re: importin shp file
Ramin Safa raminsafa at yahoo.com
Thu Jun 19 20:24:10 EDT 2003
hi
Regarding my problem,i will try again.
I'm using   system : Linux and Grass5
Ramin
Moritz Lennert <mlennert at club.worldonline.be> wrote:Ramin Safa said:
> Hi,
> HELP
> I have trouble importing an Arcview shapefile.
> when i use ,< v,in.shape -1 ...>the answer is :
> Log file not specified .sending message to 'standard error' segment fault.
> what is log file? how can i solved this problem and continue?
> Ramin Safamanesh
The log file is not the problem. The message just tells you that it will
send all messages to standard error, which is probably just your screen.
However, the problem is the segmentation fault.
Could you tell us what version of GRASS you are using, on what kind of
system (GNU/Linux, UNIX, Cygwin,...) ?
Moritz
Ramin Safamanesh
Department of  Environment Science , UPM
Email :  rsafamanesh at hotmail.com Tel  :  0060122399448
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030619/6ce68ee4/attachment.html
