[GRASSLIST:491] Grid 3d
Sjors
jkwast at freeler.nl
Tue Jun 24 07:17:45 EDT 2003
hi,
Since I was playing around with site files yesterday (see awk thread,
thanks everybody) I also started to take a look at grid 3d modules. So
messing a bit around, as the docs are not many, I finally could import
my sites file and turn it to rast with s.to.rast3. Now making a display
file, I've looked at the weather example also it gives me this error:
FATAL ERROR: G3d_getDoubleRegion: error in G3d_getTilePtr
I've set up region as:
CURRENT REGION: N=6000 S= 0 RES=1 ROWS=6000
E=6270 W= 50 RES=1 COLS=6220
T=1524 B=1520 RES=1 DEPTHS=4
PROJECTION: 0 (x,y)
ZONE: 0
sitefile is imported with s.in.ascii d=3 form ascii file containing 1
value, ie xyzv1.
I think the problem is with depths values, does it stand for the values
after xyz?
Btw how to deal with dres. If 2d res ==1 can dres in 3d be 0.1?
All for now, hope somebody has a clou,
Greetings Sjors
PS
I must say that I recently installed redhat 9 and cvs head version of
grass5, with postgres , postgis and all other relevant stuff and it
went rather painlessly. However grass5 won't start in graphical mode
after first time, but I suppose that's normal.
