[GRASSLIST:5713] Re: Unrectified DXF importation
Dr. Mohamad Firuz Ramli firuz at fsas.upm.edu.my
Sun Mar 2 18:39:59 EST 2003
Dear Markus
Thanks for the tips and explaination. It works now after
I insert the -r option in the v.transform.
Firuz
On Fri, Feb 28, 2003 at 03:42:09PM +0800, Dr. Mohamad Firuz Ramli wrote:
> Dear list
> Thanks  to Sandro for helping me in my first problems
> with dxf data.
> I have another problems.
> I try to import unrectified dxf layer. I manage to do it.
> However when I did the transformation using v. transform,
> it shows the transformation process with the residual value.
> But when I tried to display the rectified dxf. It did not show anything.
> I followed the procedure in Neteler and Mitasova's book but I encounter
> a problem such as above.
> This is the procedure that I did.
> v.in.dxf -a dxf=vmap.dxf prefix=vmap      --to import dxf data into ascii
> I want to import road layer inside vmap
>  v.in.ascii in=vmap.road out=vmap_roadxy
> v.support vmap_roadxy
> g.region -p vect=vmap_roadxy
> d.erase
> d.vect vmap_roadxy
> I managed to display the vmap_roadxy layer on the screen and identify four gcpoints
> in x and y coordinates and its location on the map for the real coordinates and
> save in in ASCII table point as roadgcp
Up to now the map name is "vmap_roadxy", right?
> After that
> v.transform in=vmap_road out=vmap_roadtrans point=roadgcp    (as in Neteler and Mitasova book)
> ERROR:Could not find input vector vmap_road
Yes, because the name was wrong.
v.transform reads binary vectors only:
"   v.transform - Transforms an binary vector map layer from one
   coordinate system into another coordinate system."
i.e. the result of v.in.ascii.
> After that I change the input to the one that I convert to binary file
> v.transform in=vmap_roadxy out=vmap_roadtrans point=roadgcp
Looks better...
> The map is transformed with the residual value
> Transformation is complete
> v.support vmap_roadtrans
Here it may help to use
v.support -r vmap_roadtrans
[should we make "-r" a default?]
> g.region -p vect=vmap_roadtrans
Now hopefully shows the correct boundary coordinates.
Markus Neteler
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030303/e1ba84b2/attachment.html
