[GRASSLIST:5751] Re: Problem restarting GRASS5 with -tcltk
Glynn Clements glynn.clements at virgin.net
Fri Mar 7 02:06:40 EST 2003
Brent Wood wrote:
> I recently crashed out of a GRASS5 session. (sigh..)
> The problem now is that the tcl/tk GUI locks up with a blank window on
> startup.
Try deleting/renaming ~/.tcltkgrass and/or ~/.grassrc5.
> Starting in text mode generates an error opening monitor x0 from the
> command line,
What error, exactly?
> but opening x1 works OK. x0 was open when it crashed, & I'm
> assuming the gui is trying to  reopen x0 and failing due to something left
> hanging around from the crash.
> Hopefully someone can point me at some lock files somewhere or another
> simple fix?
No lock files are involved. It's possible that the XDRIVER process is
still running, and may need to be killed manually.
Glynn Clements <glynn.clements at virgin.net>
