[GRASSLIST:5902] Re: problem of v.out.shape
Eric G. Miller
egm2 at jps.net
Fri Mar 28 21:08:33 EST 2003
On Wed, Mar 26, 2003 at 03:19:17PM -0600, Xueming Wu wrote:
> Greetings,
> I got "segmentation fault" when I used "v.out.proj"
> to convert some vectors which was obtained by "r.poly"
> from some raster". What I do were following:
> r.poly
> v.support
> then
> v.out.proj map= type=area
> Segmentation Fault
> But if I used type of line, the conversion was done.
> i.e. v.out.proj map= type=line.
> Any idea or suggestion? Thank you.
>From the change logs for v.out.shape...
2002-10-03 22:34 eric
* extract.c: Fix memory corruption bug with areas w/ islands.
I think the version in 5.0.1 has the fixed version...
echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
