[GRASSLIST:5915] strange d.histogram mess-up and a question
Andrew
SelkiesDad at comp10680.potsdam.edu
Sun Mar 30 09:26:12 EST 2003
I have a strange problem and I was wondering if someone might have an
insight...
I have a source-compiled installation of grass 5.0pre3 that has been in use
for almost a year on a dual intel 300 MHz Linux (slackware 8.0 kernel 2.4.5)
box with 500 MB of RAM. Two days ago I copied a set of data directories for
Grass to a different drive, in their entirety, to deal with a space issue (I
have done this many times in the last 5 months without problems). I shut off
the computer until the next day. When I rebooted and started Grass the
d.histogram module no longer worked. I use this a lot and I really am
perplexed.
Symptoms: Invoke d.histogram with a selected monitor window set to the
approriate region and STDOUT echoes
"r.stats: nn%" where nn is the incremented percentage complete. When r.stats
reaches 100% the next line reads "segmentation fault" and nothing is
displayed in the monitor window.
I have tried everything I can think of (change mapsets and locations region
settings, nsteps, re-importing raster files, etc) and none of the maps
accessed behave any differently, even if they worked fine under d.histogram
the day before. I deleted all the grass files in /usr/local/grass5 and
/usr/local/bin and compiled the recent stable version of Grass (5.0.1)
without problems and installed it (I couldn't uninstall as I didn't compile
in the destination directory and did not save the install files) The problem
remains. No other modules seem to be affected.
This is a very Windows 32 kind of problem (e.g. corrupted system or
executable files perhaps caused by an abrupt shutdown, etc) and not what I
generally expect from LINUX.
Unrelated question: What rules are applied to set the defaultcolor palette
to a raster image? I would like to know if the yellow->blue->red palette set
by default uses percentage of full scale, standard deviations or some other
approach to setting the color scale.
