[GRASSLIST:5920] Re: strange d.histogram mess-up and a question
    Glynn Clements
    glynn.clements at virgin.net
    Sun Mar 30 15:36:46 EST 2003
Andrew wrote:
> Symptoms: Invoke d.histogram with a selected monitor window set to the
> approriate region and STDOUT echoes
> "r.stats: nn%" where nn is the incremented percentage complete. When r.stats
> reaches 100% the next line reads "segmentation fault" and nothing is
> displayed in the monitor window.
I suspect that tracking this down would require either the use of a
debugger or a lot of trial-and-error.
> Unrelated question: What rules are applied to set the defaultcolor palette
> to a raster image? I would like to know if the yellow->blue->red palette set
> by default uses percentage of full scale, standard deviations or some other
> approach to setting the color scale.
The assignment is linear (percentage of full scale). IOW:
	k = (x - min) / (max - min)
with k = 0 -> yellow and k = 1 -> red.
Glynn Clements <glynn.clements at virgin.net>
