[GRASSLIST:6159] Re: DEM imports to Grass - missing libproj.so
Vincent Schut
schut at sarvision.com
Thu May 1 03:42:03 EDT 2003
libproj.so comes from Proj.4, a free geographic reprojection library. You can
obtain it from http://www.remotesensing.org/proj/ .
Why GDAL needs it just to give you info on your datafile I don't know. I would
think GDAL just and only loads this lib when reprojection is needed. It is
not directly linked to it. So you will not have to recompile GDAL after
installing Proj. Just running ldconfig should do.
However, if you can compile the install of proj is easy, and it will probably
solve the error...
Regards,
Vincent Schut.
On Thursday 01 May 2003 06:40, John Doucette wrote:
> I have run gdalinfo for the dem I am trying to import. gdalinfo reports
> that it is "unable to load PROJ.4 library (libproj.so), creation of
> OGRCoordinate transformation failed."
> I don't know where libproj.so is susposed to be or when it would have been
> installed. After updating my search database (updatedb) I cannot find
> libproj.so.
> Anybody know anything about libproj.so and why gdal wants it?
> Hopefully,
> John Doucette
> ----- Original Message -----
> From: "John Doucette" <doucettj at gbis.com>
> To: "Glynn Clements" <glynn.clements at virgin.net>
> Cc: <grasslist at baylor.edu>
> Sent: Tuesday, April 29, 2003 11:03 PM
> Subject: [GRASSLIST:6154] Re: DEM imports to Grass
> > > If you have no idea regarding the format, posting more details (e.g.
> > > file names or the URL) might result in someone recognising it.
> > I am using the Big_Bald mountain dems for White Pine County, Nevada from
> > the following link.
> > http://data.geocomm.com/dem/demdownload.html
> > which is a part of www.geocomm.com
> > From: "Glynn Clements" <glynn.clements at virgin.net>
> > To: "John Doucette" <doucettj at gbis.com>
> > Sent: Tuesday, April 29, 2003 2:55 PM
> > Subject: Re: [GRASSLIST:6152] DEM imports to Grass
> > > > I am unsure how to import DEM's into Grass.
> > > It depends upon the format.
> > > > I have been trying to use DEM's from Data Depot for US topomap areas.
> I
> > am
> > > > trying to use r.in.gdal which (in man pages) says it can import USGS
> > ascii
> > > > DEM's or SDTS format. When I try either of these it get an
> "Unrecognized
> > > > format" error. What the heck?
> > > > I know that I have somehow gotten a DEM into Grass in the past but
> don't
> > > > remember how.
> > > > Can anyone give me a clue?
> > > As well as the formats which GDAL supports, raw binary DEMs (e.g.
> > > GTOPO30) can be imported with r.in.bin.
> > > Glynn Clements <glynn.clements at virgin.net>
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
