[GRASSLIST:6213] Re: Grass format in mapserver
Christian Blumer
christianblumer at yahoo.fr
Thu May 8 09:28:11 EDT 2003
Thanks, but I found another problem
when testing gdalinfo on a grass dataset I got the following error
ERROR 1: /usr/lib/libgdal.1.1.so: undefined symbol: pj_get_def
stange..strange
----- Original Message -----
To: "Christian Blumer" <christianblumer at yahoo.fr>
Sent: Thursday, May 08, 2003 3:03 PM
Subject: Re: [GRASSLIST:6206] Grass format in mapserver
> Christian Blumer wrote:
> > I am trying to let mapserver 3.6.5 read grass raster files. For this I
> > compiled gdal 1.1.8 with grass option (libgrass5 1.0.0) and recompiled
> > mapserver.
> > Desesparately, Mapserver is unable to display grass raster files and
> > keeps on telling me :
> > msDrawRaster(): Image handling error. Unrecognized or unsupported image
> > format
> > Does anyone had the same problem?
> > Christian
> Christian,
> What are you using as the filename for the layer from GRASS to
> display? I would suggest you use a complete path to the cell file in
> the cellhd directory to select the cell for your layer. See:
> http://www.remotesensing.org/gdal/frmt_grass.html
> Also, be sure you are using the right libgdal and verify that libgrass
> is working with GDAL utilities. Use gdalinfo on a cell and use
> "gdalinfo --formats" to verify that GRASS is now listed.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
