[GRASSLIST:6215] Re: Grass format in mapserver
Christian Blumer christianblumer at yahoo.fr
Thu May 8 10:07:10 EDT 2003
Fine.Reinstalling PROJ4 removes the error with gdal.
But I still can load Grass rasters in mapserver.
Christian
----- Original Message -----
To: "Christian Blumer" <christianblumer at yahoo.fr>
Sent: Thursday, May 08, 2003 3:33 PM
Subject: Re: [GRASSLIST:6213] Re: Grass format in mapserver
> Christian Blumer wrote:
> > Thanks, but I found another problem
> > when testing gdalinfo on a grass dataset I got the following error
> > ERROR 1: /usr/lib/libgdal.1.1.so: undefined symbol: pj_get_def
> > stange..strange
> Christian,
> This is normally not a fatal error even though it looks like it is.
> However, I would encourage you to download, build and install PROJ.4
> from source.   See http://www.remotesensing.org/proj.  In the next
> release of GDAL this error message will be supressed.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
