[GRASSLIST:6216] Re: Grass format in mapserver
Christian Blumer
christianblumer at yahoo.fr
Thu May 8 11:15:36 EDT 2003
gdal alone seems to work fine with libgrass.
Doing gdalinfo --formats shows grass format accessibility
Doing gdalinfo /home/blumer/GRASSDATA/global/PERMANENT/cellhd/nations
displays the content without errors
What do you mean by verifying I am getting the right libgdal?
Cheers,Christian
----- Original Message -----
To: "Christian Blumer" <christianblumer at yahoo.fr>
Sent: Thursday, May 08, 2003 4:28 PM
Subject: Re: [GRASSLIST:6215] Re: Grass format in mapserver
> Christian Blumer wrote:
> > Fine.Reinstalling PROJ4 removes the error with gdal.
> > But I still can load Grass rasters in mapserver.
> > Christian
> Christian,
> I presume you mean cannot. I don't recall your reporting the results
> from any of the steps I suggested (report from "gdalinfo --formats", the
> check to verify you are getting the right libgdal, and whether gdalinfo
> works on the full cell file path outside of mapserver or grass).
> Frankly the software works just fine, but it can be a bear to build and
> install it right, and to use it properly. If you want help debugging
> your problem you should go out of your way to try everything based on the
> information available, and to provide detailed explanations of your
> configuration and what you have tried when asking for help.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
