[GRASSLIST:10] Re: Grass format in mapserver
Christian Blumer christianblumer at yahoo.fr
Tue May 13 11:41:08 EDT 2003
Thanks a lot for your help you guys.
I finally found what was wrong.
I created the home directory of the apache user and put there all grass
data. Setting up the correct permissions made the thing work.
A bit tricky...
Christian
----- Original Message -----
To: "Christian Blumer" <christianblumer at yahoo.fr>
Sent: Friday, May 09, 2003 8:32 AM
Subject: Re: [GRASSLIST:6216] Re: Grass format in mapserver
> Christian Blumer wrote:
> > Thanks, I start to understand a bit better.
> > I indeed locate several libgdal.1.1.so files. However doing ldd on
gdalinfo
> > or on mapserv shows that they points to the correct libgdal. Renaming
this
> > one makes mapserv to fail.
> > Runing shp2img with my grass.map I am trying to use creates the correct
> > out.png image I want to see in mapserver window...
> > what else can I do?
> Christian,
> Hmm.  That is interesting. Note that ldd run "as you" may give different
> results than the shared library that would be used by mapserv when run
> as "nobody" by the web server.  However, your problem might also relate
> to permissions on the GRASS files, or the lack of a .grassrc for the
> account under which cgi-bin executables run.  As suggested earlier today
on
> on the grass list, try copying your .grassrc (.grassrc5?) to the home
> directory of the nobody user.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
