[GRASSLIST:26] Re: Grass format in mapserver
Radim Blazek
blazek at itc.it
Thu May 15 03:42:55 EDT 2003
On Tuesday 13 May 2003 05:41 pm, Christian Blumer wrote:
> Thanks a lot for your help you guys.
> I finally found what was wrong.
> I created the home directory of the apache user and put there all grass
> data. Setting up the correct permissions made the thing work.
> A bit tricky...
Mapserver -> gdal -> libgrass -> G_gisinit_2() -> G__mapset_permissions()
which checks if process is mapset owner with write permissions.
Radim
