[GRASSLIST:6222] Re: Grass & R - Solved
Daniel Victoria
daniel_victoria at yahoo.com
Thu May 8 15:32:31 EDT 2003
I solved it but don't know what the problem was.
Command line editing did work and I had installed R
using a mandrake rmp (mandrake is very much like Red
Hat). But I just compiled the new R version 1.7 and
also installed the GRASS extension v 0.2-8 and now
command line editing does not work but at least when I
quit R from inside grass the terminal works ok.
Thanks for the attention
Daniel
> > > > Hi all,
> > > > Recentlly I started using R inside Grass but a
> > > small
> > > > problem is occuring. When I quit R, my
> terminal
> > > won't
> > > > show the keys I type. Everithing works fine
> but
> > > > whatever I type is not shown. I'm usin grass
> > > 5.0.2, R
> > > > 1.6.1 and GRASS PKG 0.1-11
> > > Could you say which platform and OS you are
> using?
> > > Does command line
> > > editing work in R? Which shell do you use? R is
> most
> > > likely using
> > > readline, and your shell may too.
> > I'm using mandrake linux and bash shell. If by
> command
> > line editing you mean the up arrow to repeat the
> last
> > command then it's a yes or else I'm afraid I don't
> > know what that is :)
> OK. Do the arrow keys sideways move you backwards
> and forwards in the
> command line? When you have retrieved a previous
> command line, can you
> change it (type into it after having gone to the
> left end with the Home
> key? Something seems to be happening when you leave
> R to make the terminal
> window go "insane", sometimes typing
> stty sane
> helps, it resets the way the keyboard input is
> displayed on the terminal.
> Does the same thing happen if you just run R by
> itself without GRASS, i.e.
> leaving R makes the terminal unusable? How did you
> install R (rpm? compile
> from source?)?
> I don't have access to Mandrake, but we can carry on
> looking for things.
> Roger
> > Thanks
> > Daniel
> > > > Thanks
> > > > Daniel
> > > Roger Bivand
> > > Economic Geography Section, Department of
> Economics,
> > > Norwegian School of
> > > Economics and Business Administration,
> Breiviksveien
> > > 40, N-5045 Bergen,
> > > Norway. voice: +47 55 95 93 55; fax +47 55 95 93
> 93
> > > e-mail: Roger.Bivand at nhh.no
> > __________________________________
> > Do you Yahoo!?
> > The New Yahoo! Search - Faster. Easier. Bingo.
> > http://search.yahoo.com
> Roger Bivand
> Economic Geography Section, Department of Economics,
> Norwegian School of
> Economics and Business Administration, Breiviksveien
> 40, N-5045 Bergen,
> Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
Do you Yahoo!?
