[GRASSLIST:15] Re: GRASS 5.0.2 on Mac OSX and libdl.1.dylib
Glynn Clements glynn.clements at virgin.net
Wed May 14 20:24:05 EDT 2003
Nick Cahill wrote:
> I just installed GRASS 5.0.2 over an earlier installation of 5.0.0 from
> the Open OSX CD, and now NVIZ quits with the following error:
> dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library:
> /usr/local/lib/libdl.1.dylib  (No such file or directory, errno = 2)
> child killed: trace trap
>      while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=dem.city.2
> -name NVIZ >&@stdout"
> It's looking for /usr/local/lib/libdl.1.dylib. I have libdl.0.dylib,
> and libdl.dylib, but no .1. What program installs this?
libdl is a system library, i.e. it will be installed as part of MacOSX
itself.
I suspect that you may need an OS upgrade (unless OpenOSX decide to
release a GRASS CD which works with older OS versions).
Glynn Clements <glynn.clements at virgin.net>
