[GRASSLIST:44] Re: Newbie Region Problems
R. Sean Fulton
fulton at cmu.edu
Thu May 15 13:45:03 EDT 2003
At 6:00 PM +0200 2003/05/15, Moritz Lennert wrote:
>R. Sean Fulton said:
>> Hello,
>> I'm trying to combine some raster and vector data from
>> www.pasda.psu.edu (links below). The raster (DOQ) and vector (SHAPE)
>> are in different projections. I've created locations for each and
>> imported them. When I re-project with v.proj (or r.proj) the two,
>> which should overlap, are no where near each other.
>> The region for the raster was set with info from gdalinfo and worked
>> straight away, i.e. I could d.rast and see it. The vector files meta
>> data had bounding coordinates that appear to be in lat/lon and so
>> were useless for its projection (aea). Setting the region from the
>> vector once it was imported seemed to work though.
>> Now the only problem is that, when combined, the two regions don't
>> overlap.
>> Are there any good primers on projections and grass regions and
>> importing data? I couldn't find anything useful on the web-site.
>Have you tried the Tutorial at http://grass.itc.it/gdp/grass5tutor/,
>especially the chapter called "The GRASS Region" ?
>Moritz
Thanks, Moritz. I hadn't come across this document before.
Sean
