[GRASSLIST:48] Re: problem to run grass5
Glynn Clements
glynn.clements at virgin.net
Thu May 15 20:57:12 EDT 2003
Roberto Rosado Solorzano wrote:
> I've just installed grass5 in a Sun WS with sunOS solaris8, for this I
> downloaded the precompiled binary "grass-5.0.0pre3-sol8-sparc-opt".
> After the welcoming screen and hit "enter" I've got the next response:
> "ld.so.1: /opt/GNUgrass/grass5/set_data: fatal: libncurse.so.5: open
> failed: no such file or directory
> Killed"
> The case is that I've got ncurses5.3 preinstalled at /usr/local and that
> library (libncurse.so.5) is at /usr/local/lib . . .
But is /usr/local/lib being searched by the loader?
I don't know for sure about Solaris, but Linux' handling of shared
libraries is quite close to Solaris, and Linux' loader doesn't look in
/usr/local/lib by default. You have to either:
a) add /usr/local/lib to /etc/ld.so.conf then run ldconfig (and re-run
it whenever new libraries are added), or
b) add /usr/local/lib to LD_LIBRARY_PATH.
> maybe another package is missing, but I don't know which one . . .
> could anybody have an idea??
Try "ldd /opt/GNUgrass/grass5/set_data"; that should tell you exactly
which libraries are required and whether (and where) they are found.
Glynn Clements <glynn.clements at virgin.net>
