[GRASSLIST:55] Re: More Solaris 9 problems - NVIZ
Bernhard Reiter
bernhard at intevation.de
Fri May 16 12:23:09 EDT 2003
On Fri, May 16, 2003 at 05:07:20PM +0100, Ade Fewings wrote:
> I have now got Grass 5.0.2 building and working on Sol9 except for NVIZ
> which doesn't build, with 'make' giving the following errors:
> GRASS GIS source code compiled.
> Compilation error in module: src/general/g.region (ignored)
> Compilation error in module: src/imagery/i.points3 (ignored)
> Compilation error in module: src/mapdev/v.digit (ignored)
> Compilation error in module: src/mapdev/v.in.gshhs (ignored)
> Compilation error in module: src/mapdev/v.mkquads (ignored)
> Compilation error in module: src/mapdev/v.proj (ignored)
> Compilation error in module: src/misc/m.proj2 (ignored)
> Compilation error in module: src/raster/r.in.gdal (ignored)
> Compilation error in module: src/raster/r.proj (ignored)
> Compilation error in module: src/raster/r.sun (ignored)
> Compilation error in module: src/raster/r.sunmask (ignored)
> Compilation error in module: src/sites/s.proj (ignored)
> Compilation error in module: src/display/devices/PNGdriver (ignored)
> Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
> Understanding not enough about the build process, does this mean that
> the reason NVIZ2.2 won't build is because of problems with the
> previously mentioned compile problems?
No, there are separate error messages for each of the modules
and probably differnet problems.
The nviz problem below seems to be related to tcl/tk,
so what versions to you have for that?
Please give the details on the developers list.
> NVIZ's error is:
> make[2]: Entering directory
> `/export/data0/build/grass5.0.2/src.contrib/GMSL/NVIZ2.2/src'
> gcc -I/export/data0/build/grass5.0.2/src/include -g -O2
> -I/export/data0/build/grass5.0.2/src/libes/ogsf -D_NO_PROTO -D__STDC__
> -I/usr/local/pgsql/include -c nvizAppInit.c -o
> OBJ.sparc-sun-solaris2.9/nvizAppInit.o
> <command line>:1:1: warning: "__STDC__" redefined
> In file included from nvizAppInit.c:9:
> interface.h:257: conflicting types for `Tk_SetAppName'
> /usr/local/include/tkDecls.h:573: previous declaration of `Tk_SetAppName'
> make[2]: *** [OBJ.sparc-sun-solaris2.9/nvizAppInit.o] Error 1
> make[2]: Leaving directory
> Which i find very strange. I'm using Sol9 with GCC3.2.2 from
> sunfreeware.com and most of the other stuff on the 'requirements for
> grass' page freshly fetched and built in their latest incarnations.
> It's all in /usr/local and yet i'm still having these problems.
> Would very much appreciate any wise words from anybody.....
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20030516/ac77f2b6/attachment.bin
