[GRASSLIST:56] GRASS 5.0.2 on Mac OSX and libdl.1.dylib - solved
    Nick Cahill
    ndcahill at facstaff.wisc.edu
    Fri May 16 14:13:34 EDT 2003
Installing the latest version of dlcompat (available at
http://www.opendarwin.org/projects/dlcompat/) fixed this. You need to
have the (free) developer's tools from Apple installed. Dlcompat is a
tiny download; the developer's tools is a huge download (300 meg or
something). If anyone would like I can email them the libdl.1.dylib
file; just putting that in /usr/local/lib might work, although I can't
test this myself.
For what it's worth, GRASS 5.0.2 running under Apple's X11 is *much*
faster than 5.0.0 under the older version of XDarwin. It's probably the
hardware acceleration in Apple X11; the difference is striking.
Nick Cahill
>>> It's looking for /usr/local/lib/libdl.1.dylib. I have libdl.0.dylib,
>>> and libdl.dylib, but no .1. What program installs this?
>> libdl is a system library, i.e. it will be installed as part of MacOSX
>> itself.
>> I suspect that you may need an OS upgrade (unless OpenOSX decide to
>> release a GRASS CD which works with older OS versions).
> It appears that I was mistaken. libdl is a system library on "typical"
> Unix systems (e.g. Linux, Solaris). MacOSX provides a different API,
> but there is a third-party libdl "emulation":
> My (updated) guess is that the OpenOSX port uses this library (or a
> similar library from another source), but they forgot to include it on
> the CD.
> Copying or renaming libdl.0.dylib to libdl.1.dylib *might* work,
> although a change to the version number is normally made to indicate
> incompatibility (i.e. to prevent programs from using an incompatible
> library).
> If it doesn't work, the only options are to either ask OpenOSX.com to
> provide the library which they used, or to build it yourself.
> Glynn Clements <glynn.clements at virgin.net>
