[GRASSLIST:71] Re: More Solaris 9 problems - NVIZ
Glynn Clements
glynn.clements at virgin.net
Sat May 17 12:37:25 EDT 2003
Ade Fewings wrote:
> > ISTR that the NVIZ error has already been identified, and is fixed in
> > the CVS HEAD.
> > I suspect that most of the errors are related to the projection code;
> > only 15 GRASS modules use the projection library, and 10 of them are
> > in the above list.
> > The PNGdriver error is probably related to the problems which you've
> > been having with GD.
> > We need to see the actual error messages from "make" in order to be
> > able to do anything about these problems.
> Thanks for your replies. I've had a look at the 'make' output and cut
> out the relevant parts and they're quoted at the bottom of this mail.
> But, the problem is the same in all cases except PNGdriver and the
> original NVIZ problem - all to do with symbol LLC24.
> make[2]: Entering directory
> `/export/data0/build/grass5.0.2/src/general/g.region/cmd'
> gcc -L/export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9
> -o /export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cm
> d/g.region OBJ.sparc-sun-solaris2.9/printwindow.o
> OBJ.sparc-sun-solaris2.9/adjust.o OBJ.sparc-sun-solaris2.9/main.o
> OBJ.sparc-sun-solaris2.9/zo
> om.o -lvect -ldig2 -lgis -lsocket -ldatetime -lproj -lm -lnsl -lz
> ld: warning: relocation error: R_SPARC_32: file
> /export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9/libproj.a(PJ_krovak.o):
> symbol .LLC24:
> external symbolic relocation against non-allocatable section .stab;
> cannot be processed at runtime: relocation ignored
[snip]
> Undefined first referenced
> symbol in file
> .LLC24 /export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9/libproj.a(PJ_krovak.o)
> ld: fatal: Symbol referencing errors. No output written to
> /export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/g.region
> collect2: ld returned 1 exit status
That symbol isn't related to libproj; the fact that it begins with a
dot suggests something internal.
I note that all of the errors refer to PJ_krovak.o and PJ_krovakgis.o.
The most obvious difference between these two files and all of the
others in libproj is that they include <stdio.h> and <string.h>, and
they do so after they have included "projects.h".
AFAICT, those headers are only used by some debug code which is
disabled. I suggest changing the top of each of those files from:
#include "projects.h"
#include <string.h>
#include <stdio.h>
to just:
> make[1]: Entering directory
> `/export/data0/build/grass5.0.2/src/display/devices/PNGdriver'
> -o /export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/driver/PNG
> OBJ.spar
> c-sun-solaris2.9/Can_do.o OBJ.sparc-sun-solaris2.9/Clr_table.o
> OBJ.sparc-sun-solaris2.9/Color.o OBJ.sparc-sun-solaris2.9/Draw_line.o
> OBJ.sparc-sun-solar
> is2.9/Get_w_box.o OBJ.sparc-sun-solaris2.9/Get_w_line.o
> OBJ.sparc-sun-solaris2.9/Get_w_pnt.o
> OBJ.sparc-sun-solaris2.9/Graph_Clse.o OBJ.sparc-sun-solaris
> 2.9/Graph_Set.o OBJ.sparc-sun-solaris2.9/Panel.o
> OBJ.sparc-sun-solaris2.9/Polygn_abs.o -ldriver -lgis -lsocket -lnsl
> -lz -lgd
> symbol in file
> sin
Contrary to my previous guess, this *isn't* a problem with your GD
library; the display drivers themselves need the math library (for
drawing rotated text), but the Gmakefile for PNGdriver doesn't specify
it.
In src/display/devices/PNGdriver/Gmakefile, change line 29 from
$(CC) $(LDFLAGS) -o $@ $(OFILES) $(LIBES) $(XDRLIB) $(GDLIB)
to:
$(CC) $(LDFLAGS) -o $@ $(OFILES) $(LIBES) $(XDRLIB) $(GDLIB) $(MATHLIB)
Glynn Clements <glynn.clements at virgin.net>
