[GRASSLIST:70] Re: More Solaris 9 problems - NVIZ
    Ade Fewings
    ade at informatics.bangor.ac.uk
    Sat May 17 11:52:29 EDT 2003
Glynn Clements wrote:
>Ade Fewings wrote:
>>Would appreciate any help with what has become an unsurmountable problem
>>here at the moment.....
>>I have now got Grass 5.0.2 building and working on Sol9 except for NVIZ
>>which doesn't build, with 'make' giving the following errors:
>>GRASS GIS source code compiled.
>>Compilation error in module: src/general/g.region (ignored)
>>Compilation error in module: src/imagery/i.points3 (ignored)
>>Compilation error in module: src/mapdev/v.digit (ignored)
>>Compilation error in module: src/mapdev/v.in.gshhs (ignored)
>>Compilation error in module: src/mapdev/v.mkquads (ignored)
>>Compilation error in module: src/mapdev/v.proj (ignored)
>>Compilation error in module: src/misc/m.proj2 (ignored)
>>Compilation error in module: src/raster/r.in.gdal (ignored)
>>Compilation error in module: src/raster/r.proj (ignored)
>>Compilation error in module: src/raster/r.sun (ignored)
>>Compilation error in module: src/raster/r.sunmask (ignored)
>>Compilation error in module: src/sites/s.proj (ignored)
>>Compilation error in module: src/display/devices/PNGdriver (ignored)
>>Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
>>Understanding not enough about the build process, does this mean that
>>the reason NVIZ2.2 won't build is because of problems with the
>>previously mentioned compile problems?  NVIZ's error is:
>ISTR that the NVIZ error has already been identified, and is fixed in
>the CVS HEAD.
>I suspect that most of the errors are related to the projection code;
>only 15 GRASS modules use the projection library, and 10 of them are
>in the above list.
>The PNGdriver error is probably related to the problems which you've
>been having with GD.
>We need to see the actual error messages from "make" in order to be
>able to do anything about these problems.
Thanks for your replies.  I've had a look at the 'make' output and cut
out the relevant parts and they're quoted at the bottom of this mail.
But, the problem is the same in all cases except PNGdriver and the
original NVIZ problem - all to do with symbol LLC24.
The version of TCL/TK i'm using is 8.4.1.
BTW, should i move this to the developer list?
Many thanks,
Ade
/export/data0/build/grass5.0.2/src/general/g.region/cmd
  make -f OBJ.sparc-sun-solaris2.9/make.rules
make[2]: Entering directory
`/export/data0/build/grass5.0.2/src/general/g.region/cmd'
gcc -L/export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9
-o /export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cm
d/g.region OBJ.sparc-sun-solaris2.9/printwindow.o
OBJ.sparc-sun-solaris2.9/adjust.o OBJ.sparc-sun-solaris2.9/main.o
OBJ.sparc-sun-solaris2.9/zo
om.o -lvect -ldig2 -lgis -lsocket  -ldatetime -lproj -lm  -lnsl    -lz
ld: warning: relocation error: R_SPARC_32: file
/export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9/libproj.a(PJ_krovak.o):
symbo
l .LLC24:
        external symbolic relocation against non-allocatable section .stab;
        cannot be processed at runtime: relocation ignored
symbo
l .LLC24:
/export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9/libproj.a(PJ_krovakgis.o):
sy
mbol .LLC24:
sy
mbol .LLC24:
Undefined                       first referenced
 symbol                             in file
.LLC24
ld: fatal: Symbol referencing errors. No output written to
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/g.region
collect2: ld returned 1 exit status
make[2]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/g.region]
Error 1
make[2]: Leaving directory
make[1]: *** [all] Error 1
make[1]: Leaving directory
`/export/data0/build/grass5.0.2/src/general/g.region'
GISGEN failure at STEP: src/general/g.region
GISGEN: src/general/g.tempfile - Sat May 17 16:17:50 BST 2003
/export/data0/build/grass5.0.2/src/imagery/i.points3/inter
`/export/data0/build/grass5.0.2/src/imagery/i.points3/inter'
-o /export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/in
ter/i.points3 OBJ.sparc-sun-solaris2.9/anal_fid.o
OBJ.sparc-sun-solaris2.9/anal_control.o
OBJ.sparc-sun-solaris2.9/camera.o OBJ.sparc-sun-solar
is2.9/camera_mod.o OBJ.sparc-sun-solaris2.9/digit.o
OBJ.sparc-sun-solaris2.9/draw_cell.o
OBJ.sparc-sun-solaris2.9/draw_grid.o OBJ.sparc-sun-sol
aris2.9/draw_vect.o OBJ.sparc-sun-solaris2.9/driver.o
OBJ.sparc-sun-solaris2.9/expose_mod.o
OBJ.sparc-sun-solaris2.9/graph_ask.o OBJ.sparc-sun-
solaris2.9/graph_askmag.o OBJ.sparc-sun-solaris2.9/graph_dot.o
OBJ.sparc-sun-solaris2.9/graph_init.o
OBJ.sparc-sun-solaris2.9/graph_title.o OBJ
.sparc-sun-solaris2.9/input.o OBJ.sparc-sun-solaris2.9/list_colors.o
OBJ.sparc-sun-solaris2.9/list_group.o OBJ.sparc-sun-solaris2.9/list_target
.o OBJ.sparc-sun-solaris2.9/main.o OBJ.sparc-sun-solaris2.9/mark_fid.o
OBJ.sparc-sun-solaris2.9/mark_control.o OBJ.sparc-sun-solaris2.9/mouse.o
 OBJ.sparc-sun-solaris2.9/overlay.o OBJ.sparc-sun-solaris2.9/plot.o
OBJ.sparc-sun-solaris2.9/plot_cell.o OBJ.sparc-sun-solaris2.9/plot_grid.o O
BJ.sparc-sun-solaris2.9/plot_vect.o OBJ.sparc-sun-solaris2.9/read_elev.o
OBJ.sparc-sun-solaris2.9/target.o OBJ.sparc-sun-solaris2.9/transform.o
 OBJ.sparc-sun-solaris2.9/view_config.o
OBJ.sparc-sun-solaris2.9/view_clear.o
OBJ.sparc-sun-solaris2.9/view_colors.o OBJ.sparc-sun-solaris2.9/v
iew_conv.o OBJ.sparc-sun-solaris2.9/view_outline.o
OBJ.sparc-sun-solaris2.9/view_points.o
OBJ.sparc-sun-solaris2.9/view_refresh.o OBJ.sparc-sun
-solaris2.9/view_where.o OBJ.sparc-sun-solaris2.9/zoom_box.o
OBJ.sparc-sun-solaris2.9/zoom_pnt.o -lI -limage_sup -lD -ldisplay
-lraster -lvect
-ldig2 -lproj -lgis -lsocket  -lvask -lncurses  -lm  -lnsl    -lz
symbo
l .LLC24:
symbo
l .LLC24:
sy
mbol .LLC24:
sy
mbol .LLC24:
 symbol                             in file
.LLC24
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/inter/i.points3
make[2]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/inter/i.points3]
Error 1
`/export/data0/build/grass5.0.2/src/imagery/i.points3'
GISGEN failure at STEP: src/imagery/i.points3
GISGEN: src/imagery/i.quantize - Sat May 17 16:17:59 BST 2003
/export/data0/build/grass5.0.2/src/mapdev/v.digit
make[1]: Entering directory
`/export/data0/build/grass5.0.2/src/mapdev/v.digit'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/inter/v.dig
it OBJ.sparc-sun-solaris2.9/add_scale.o OBJ.sparc-sun-solaris2.9/area.o
OBJ.sparc-sun-solaris2.9/ask_driver.o
OBJ.sparc-sun-solaris2.9/backdrop.o OBJ.sp
arc-sun-solaris2.9/bad_areas.o OBJ.sparc-sun-solaris2.9/break.o
OBJ.sparc-sun-solaris2.9/build_neat.o
OBJ.sparc-sun-solaris2.9/coll_pts.o OBJ.sparc-sun-
solaris2.9/color.o OBJ.sparc-sun-solaris2.9/compress.o
OBJ.sparc-sun-solaris2.9/contour.o OBJ.sparc-sun-solaris2.9/customize.o
debug.o OBJ.sparc-sun-solaris2.9/debugf.o
OBJ.sparc-sun-solaris2.9/dig_curses.o OBJ.sparc-sun-solaris2.9/dig_dev.o
OBJ.sparc-sun-solaris2.9/digitize.o O
BJ.sparc-sun-solaris2.9/digmain.o OBJ.sparc-sun-solaris2.9/discio.o
OBJ.sparc-sun-solaris2.9/display_area.o
OBJ.sparc-sun-solaris2.9/display_line.o OBJ.
sparc-sun-solaris2.9/display_site.o
OBJ.sparc-sun-solaris2.9/display_node.o
OBJ.sparc-sun-solaris2.9/drawcell.o OBJ.sparc-sun-solaris2.9/duplicate.o OBJ
.sparc-sun-solaris2.9/edit.o OBJ.sparc-sun-solaris2.9/eq.o
OBJ.sparc-sun-solaris2.9/find_w_mouse.o
OBJ.sparc-sun-solaris2.9/find_w_dig.o OBJ.sparc-sun-s
olaris2.9/flush.o OBJ.sparc-sun-solaris2.9/flush_input.o
OBJ.sparc-sun-solaris2.9/get_point.o
OBJ.sparc-sun-solaris2.9/get_diginput.o OBJ.sparc-sun-sola
ris2.9/gorun.o OBJ.sparc-sun-solaris2.9/graph_input.o
OBJ.sparc-sun-solaris2.9/graphics.o OBJ.sparc-sun-solaris2.9/head_info.o
help.o OBJ.sparc-sun-solaris2.9/initialize.o
OBJ.sparc-sun-solaris2.9/interact.o OBJ.sparc-sun-solaris2.9/interface.o
OBJ.sparc-sun-solaris2.9/intersect
.o OBJ.sparc-sun-solaris2.9/isle.o OBJ.sparc-sun-solaris2.9/label.o
OBJ.sparc-sun-solaris2.9/label_mult.o OBJ.sparc-sun-solaris2.9/leave.o
OBJ.sparc-sun
-solaris2.9/list.o OBJ.sparc-sun-solaris2.9/main.o
OBJ.sparc-sun-solaris2.9/map_ask.o
OBJ.sparc-sun-solaris2.9/map_ask_new.o OBJ.sparc-sun-solaris2.9/ma
p_coor_new.o OBJ.sparc-sun-solaris2.9/map_init_new.o
OBJ.sparc-sun-solaris2.9/map_reg.o
OBJ.sparc-sun-solaris2.9/map_residnew.o OBJ.sparc-sun-solaris2.9
/map_scale.o OBJ.sparc-sun-solaris2.9/menus.o
OBJ.sparc-sun-solaris2.9/mk_window.o OBJ.sparc-sun-solaris2.9/mouse_yn.o
OBJ.sparc-sun-solaris2.9/mouse_co
ll.o OBJ.sparc-sun-solaris2.9/move_line.o
OBJ.sparc-sun-solaris2.9/move_point.o
OBJ.sparc-sun-solaris2.9/new_line.o OBJ.sparc-sun-solaris2.9/node_color.
o OBJ.sparc-sun-solaris2.9/node_lines.o OBJ.sparc-sun-solaris2.9/oplot.o
OBJ.sparc-su
n-solaris2.9/read_cap.o OBJ.sparc-sun-solaris2.9/remove.o
OBJ.sparc-sun-solaris2.9/remove_block.o
OBJ.sparc-sun-solaris2.9/replot.o OBJ.sparc-sun-solari
s2.9/reset_map.o OBJ.sparc-sun-solaris2.9/retype_line.o
OBJ.sparc-sun-solaris2.9/scal_window.o
OBJ.sparc-sun-solaris2.9/screen_plt.o OBJ.sparc-sun-solar
is2.9/select_digit.o OBJ.sparc-sun-solaris2.9/set_key.o
OBJ.sparc-sun-solaris2.9/set_thresh.o
OBJ.sparc-sun-solaris2.9/set_window.o OBJ.sparc-sun-solari
s2.9/slid_window.o OBJ.sparc-sun-solaris2.9/spline.o
OBJ.sparc-sun-solaris2.9/snap.o OBJ.sparc-sun-solaris2.9/states.o
OBJ.sparc-sun-solaris2.9/str.o OB
J.sparc-sun-solaris2.9/toolbox.o OBJ.sparc-sun-solaris2.9/where_am_i.o
OBJ.sparc-sun-solaris2.9/wind_conv.o
OBJ.sparc-sun-solaris2.9/wind_2_box.o OBJ.sp
arc-sun-solaris2.9/window.o OBJ.sparc-sun-solaris2.9/window_setup.o
OBJ.sparc-sun-solaris2.9/window_rout.o
OBJ.sparc-sun-solaris2.9/withinthresh.o -lvec
t -ldig2 -lproj
/export/data0/build/grass5.0.2/src/libes/vect32/libes/LIB.sparc-sun-solaris2.9/libtrans.a
-ldig_atts -ldisplay -lraster -lvask -lgis -ls
ocket  -lncurses  -lm  -lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/inter/v.digit
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/inter/v.digit]
Error 1
GISGEN failure at STEP: src/mapdev/v.digit
GISGEN: src/mapdev/v.distance - Sat May 17 16:18:05 BST 2003
/export/data0/build/grass5.0.2/src/mapdev/v.in.gshhs
`/export/data0/build/grass5.0.2/src/mapdev/v.in.gshhs'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.in.gs
hhs OBJ.sparc-sun-solaris2.9/main.o -lgis -lsocket  -lvect -ldig2
-ldig_atts -lproj -lm  -lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.in.gshhs
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.in.gshhs]
Error 1
GISGEN failure at STEP: src/mapdev/v.in.gshhs
GISGEN: src/mapdev/v.in.shape - Sat May 17 16:18:09 BST 2003
/export/data0/build/grass5.0.2/src/mapdev/v.mkquads
`/export/data0/build/grass5.0.2/src/mapdev/v.mkquads'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.mkqua
ds OBJ.sparc-sun-solaris2.9/mkquads_cmd.o
OBJ.sparc-sun-solaris2.9/ask_for.o OBJ.sparc-sun-solaris2.9/calc_quads.o
OBJ.sparc-sun-solaris2.9/convert.o OB
J.sparc-sun-solaris2.9/init_head.o OBJ.sparc-sun-solaris2.9/init_quad.o
OBJ.sparc-sun-solaris2.9/reg_quads.o
OBJ.sparc-sun-solaris2.9/report_quads.o OBJ
.sparc-sun-solaris2.9/sites_quads.o
OBJ.sparc-sun-solaris2.9/wind_quads.o
OBJ.sparc-sun-solaris2.9/write_quads.o -lgis -lsocket  -lvect -ldig2
-lproj -l
coorcnv  -ldatetime -lm  -lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.mkquads
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.mkquads]
Error 1
GISGEN failure at STEP: src/mapdev/v.mkquads
GISGEN: src/mapdev/v.out.arc - Sat May 17 16:18:10 BST 2003
/export/data0/build/grass5.0.2/src/mapdev/v.proj
`/export/data0/build/grass5.0.2/src/mapdev/v.proj'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.proj
OBJ.sparc-sun-solaris2.9/main.o OBJ.sparc-sun-solaris2.9/setenv.o
-lproj -lvect -ldig2 -ldig_atts -lgis -lsocket    -lm  -lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/v.proj]
Error 1
GISGEN failure at STEP: src/mapdev/v.proj
GISGEN: src/mapdev/v.prune - Sat May 17 16:18:12 BST 2003
/export/data0/build/grass5.0.2/src/misc/m.proj2
`/export/data0/build/grass5.0.2/src/misc/m.proj2'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/m.proj2
 OBJ.sparc-sun-solaris2.9/main.o OBJ.sparc-sun-solaris2.9/get_deg.o
OBJ.sparc-sun-solaris2.9/get_stp.o OBJ.sparc-sun-solaris2.9/geo_func.o
OBJ.sparc-sun
-solaris2.9/process.o OBJ.sparc-sun-solaris2.9/input.o
OBJ.sparc-sun-solaris2.9/output.o -lgis -lsocket  -lproj -lm  -lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/m.proj2]
Error 1
make[1]: Leaving directory `/export/data0/build/grass5.0.2/src/misc/m.proj2'
GISGEN failure at STEP: src/misc/m.proj2
GISGEN: src/misc/m.region.ll - Sat May 17 16:18:20 BST 2003
/export/data0/build/grass5.0.2/src/raster/r.in.gdal
`/export/data0/build/grass5.0.2/src/raster/r.in.gdal'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.in.gd
al OBJ.sparc-sun-solaris2.9/main.o
OBJ.sparc-sun-solaris2.9/gbgetsymbol.o
OBJ.sparc-sun-solaris2.9/gdalbridge.o OBJ.sparc-sun-solaris2.9/make_loc.o \
        -ldl -lgis -lsocket  -lI -lproj -lm  -lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.in.gdal
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.in.gdal]
Error 1
GISGEN failure at STEP: src/raster/r.in.gdal
GISGEN: src/raster/r.in.gridatb - Sat May 17 16:18:39 BST 2003
/export/data0/build/grass5.0.2/src/raster/r.proj/cmd
`/export/data0/build/grass5.0.2/src/raster/r.proj/cmd'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.proj
OBJ.sparc-sun-solaris2.9/main.o OBJ.sparc-sun-solaris2.9/bordwalk.o
OBJ.sparc-sun-solaris2.9/readcell.o OBJ.sparc-sun-solaris2.9/nearest.o
OBJ.sparc-sun
-solaris2.9/bilinear.o OBJ.sparc-sun-solaris2.9/cubic.o -lproj -lgis
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
make[2]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.proj]
Error 1
`/export/data0/build/grass5.0.2/src/raster/r.proj'
GISGEN failure at STEP: src/raster/r.proj
GISGEN: src/raster/r.quant - Sat May 17 16:18:51 BST 2003
/export/data0/build/grass5.0.2/src/raster/r.sun
`/export/data0/build/grass5.0.2/src/raster/r.sun'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.sun O
BJ.sparc-sun-solaris2.9/main.o -lgis -lsocket  -lproj -llinkm -lm
-lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.sun]
Error 1
make[1]: Leaving directory `/export/data0/build/grass5.0.2/src/raster/r.sun'
GISGEN failure at STEP: src/raster/r.sun
GISGEN: src/raster/r.sunmask - Sat May 17 16:18:56 BST 2003
/export/data0/build/grass5.0.2/src/raster/r.sunmask
`/export/data0/build/grass5.0.2/src/raster/r.sunmask'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.sunma
sk OBJ.sparc-sun-solaris2.9/main.o OBJ.sparc-sun-solaris2.9/solpos00.o
OBJ.sparc-sun-solaris2.9/g_solposition.o -lgis -lsocket  -lproj  -lm
-lnsl    -l
z
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.sunmask
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/r.sunmask]
Error 1
GISGEN failure at STEP: src/raster/r.sunmask
GISGEN: src/raster/r.support - Sat May 17 16:18:56 BST 2003
/export/data0/build/grass5.0.2/src/sites/s.proj
`/export/data0/build/grass5.0.2/src/sites/s.proj'
-o
/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/s.proj
OBJ.sparc-sun-solaris2.9/main.o -lproj -lgis -lsocket    -ldatetime -lm
-lnsl    -lz
symbol .LLC24:
symbol .LLC24:
symbol .LLC
24:
symbol .LLC
24:
 symbol                             in file
.LLC24
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/etc/bin/cmd/s.proj]
Error 1
make[1]: Leaving directory `/export/data0/build/grass5.0.2/src/sites/s.proj'
GISGEN failure at STEP: src/sites/s.proj
GISGEN: src/sites/s.qcount - Sat May 17 16:19:08 BST 2003
/export/data0/build/grass5.0.2/src/display/devices/PNGdriver
`/export/data0/build/grass5.0.2/src/display/devices/PNGdriver'
-o /export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/driver/PNG
OBJ.spar
c-sun-solaris2.9/Can_do.o OBJ.sparc-sun-solaris2.9/Clr_table.o
OBJ.sparc-sun-solaris2.9/Color.o OBJ.sparc-sun-solaris2.9/Draw_line.o
OBJ.sparc-sun-solar
is2.9/Get_w_box.o OBJ.sparc-sun-solaris2.9/Get_w_line.o
OBJ.sparc-sun-solaris2.9/Get_w_pnt.o
OBJ.sparc-sun-solaris2.9/Graph_Clse.o OBJ.sparc-sun-solaris
2.9/Graph_Set.o OBJ.sparc-sun-solaris2.9/Panel.o
OBJ.sparc-sun-solaris2.9/Polygn_abs.o -ldriver -lgis -lsocket  -lnsl
-lz  -lgd
 symbol                             in file
sin
/export/data0/build/grass5.0.2/src/libes/LIB.sparc-sun-solaris2.9/libdriver.a(Text2.o)
(symbol belongs to implicit
dependency /usr/lib/libm.so.1)
cos
make[1]: ***
[/export/data0/build/grass5.0.2/dist.sparc-sun-solaris2.9/driver/PNG]
Error 1
GISGEN failure at STEP: src/display/devices/PNGdriver
GISGEN: src.garden/grass.postgresql - Sat May 17 16:19:28 BST 2003
___________________________________________________
Adrian [Ade] Fewings MEng
Distributed & High Performance Computing, Informatics, UWB
Dean Street, Bangor, Gwynedd. LL57 1UT. UK.
ade at informatics.bangor.ac.uk  www.informatics.bangor.ac.uk/~ade
Tel: +44 (0)1248 382736       Fax: +44 (0)1248 361429
'The ideal engineer is a composite ... He is not a scientist, he
is not a mathematician, he is not a sociologist or a writer; but
he may use the knowledge and techniques of any or all of these
disciplines in solving engineering problems.'
    N. W. Dougherty, 1955
