[GRASSLIST:137] Re: Considering replacing ESRI
Morten Hulden
morten at ngb.se
Thu May 22 12:16:44 EDT 2003
On Thu, 22 May 2003, David Finlayson wrote:
> I don't think that grass can rotate rasters (ESRI can).
> I tried to get around this a few months ago by writing a Python script
> that did the work. Unfortunately, it isn't very efficient and can take
> 20 mins or so to rotate large grids. If you are interested I can send
> you the script.
Consider that after rotation the projection would no longer be what it
was. So the new raster would have to be stored in a new (XY) location.
Why not simply export tif/png, rotate with Gimp or other external image
handler, reimport into XY-location?
