[GRASSLIST:138] Re: Considering replacing ESRI
Morten Hulden morten at ngb.se
Thu May 22 12:23:23 EDT 2003
On Wed, 21 May 2003, David Strauch wrote:
> Okay, how about orienting maps to other than true north (which I think
> is called "false northing")?
I don't think this is correct. The orientation of the map is defined by
the projection. False northing/easting is just an offset in up/down,
right/left direction, but it does not change the angle toward 'north'.
