[GRASSLIST:206] Re: rotation
David Strauch dstrauch at mac.com
Mon May 26 21:53:49 EDT 2003
Dear Glynn,
Thanks.  I'll try this out.
best,
David
On Monday, May 26, 2003, at 12:05  PM, Glynn Clements wrote:
> Vector maps can be rotated with v.transform.
> If you intend to process a large number of maps using a small number
> of custom projections, it might be worth adding your custom
> projections to the PROJ library (src/libes/proj). That should allow
> you to use the [rsv].proj programs with your custom projections.
