[GRASSLIST:202] Re: rotation
Glynn Clements
glynn.clements at virgin.net
Mon May 26 18:05:19 EDT 2003
David Strauch wrote:
> If I shift to rasters I may try David Finlayson's rotation script or
> Morten Hulden's solution of exporting, rotating and reimporting into a
> new location (I'm assuming this could be done somehow without losing
> attributes). Or it may be that vector endpoints could be converted to
> sites and rotated, converted back to vector endpoints and rebuilt into
> vectors.
Vector maps can be rotated with v.transform.
> But I'm still importing various coverages and it seems potentially
> cumbersome to do this process for each one -- especially if I later
> want to readjust the orientation. I suppose I was hoping that I could
> create new locations that had different orientations, and be able to
> reproject coverages (including vectors) into these locations. It would
> be nice to do this while working (ie with geo-referencing available),
> but it looks like (the way regions are defined) at this point map
> rotation will have to wait until I'm ready to print stuff out.
If you intend to process a large number of maps using a small number
of custom projections, it might be worth adding your custom
projections to the PROJ library (src/libes/proj). That should allow
you to use the [rsv].proj programs with your custom projections.
Glynn Clements <glynn.clements at virgin.net>
