[GRASSLIST:143] Re: don't compile man/html docs
    Glynn Clements
    glynn.clements at virgin.net
    Thu May 22 17:04:56 EDT 2003
Matt Doggett wrote:
> Is there a way to recompile (make) GRASS so that it doesn't go through the
> time-consuming steps of building the man pages and html documentation?
> The way it usually happens is that I compile everything once (e.g. 'make'
> followed by 'make install') which will compile and install the
> documentation. But then I go in and tweak the configure and/or compiler
> options (or whatever) to optimize/customize the grass binaries, then I do a
> 'make clean', followed by 'make'. Re-compiling the man and html
> documentation takes a long time and is unnecessary.
See mk/README and mk/Makefile.in.
Glynn Clements <glynn.clements at virgin.net>
