[GRASSLIST:168] Re: Still having 5.0.2 problems
Glynn Clements
glynn.clements at virgin.net
Sat May 24 13:43:02 EDT 2003
Michael Ash wrote:
> I am still having some problems with the transition from
> pre3 to 5.0.2 on Cygwin/WinGRASS/Xserver.
> - Starting the monitors gives warnings (but the behavior
> seems otherwise fine). I am unable to get a clean start even
> after running various d.mon options. The problem is in 5.0.2
> but not pre3 (I reverted and checked.)
> GRASS:~ > d.mon stop=x0
> Monitor 'x0' terminated
> GRASS:~ > d.mon start=x0
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Problem selecting x0. Will try once more
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
The warnings are a known issue on Cygwin.
> - spearfish (the version I downloaded with pre3 and the
> newest version) is fine with 5.0.2
> - vector maps and site maps that I created in pre3 seem to
> be fine 5.0.2
> - raster maps that I created in pre3 have strange values
> that look like confusion among datatypes, e.g., huge
> negative numbers. I told grasslist that I would recreate
> the data in 5.0.2 and then report, and I haven't had a
> chance to do so yet. I will report as soon as I can, but
> the project is dauntingly large.
Odd; the internal format for integer maps hasn't changed since 4.3.
Is it possible that the maps were created in text mode? This will
cause \x0a to be written as \x0d\x0a.
Glynn Clements <glynn.clements at virgin.net>
