[GRASSLIST:196] Re: help with shortest distance
Moritz Lennert
mlennert at club.worldonline.be
Mon May 26 14:50:52 EDT 2003
Ganesh Kuppuswamy said:
> I'm trying to figure out the closest point from another point based on
> vector layer. I am planning to have 2 tables one for the roads and
> another
> for the points. Can v.distance help me with this?
> Also can these roads and sites be stored in a postgres database?
yes, v.distance should be the right tool, if you plan on creating road and
point maps. If you only plan on using tables, then you should think about
PostGIS: http://postgis.refractions.net/.
You might also want to look at the experimental GRASS5.1 for much better
vector and database support.
Moritz
