[GRASSLIST:262] Re: r.mapcalc with TIFFs
Peter Slizik
upsyptsl at savba.sk
Fri May 30 10:21:11 EDT 2003
Guillaume Criloux wrote:
>There is a color table associated with each raster map. You can play with it using r.colors GRASS command.
>Hope it helps,
>Guillaume
Yes, you're perfectly right. The color table for the new created map was
missing. GRASS used randomly picked colors instead. Thanks for your
suggestion.
By the way, is there any way how to export color table or copy it to the
another map?
r.colors seems to be good only for importing tables.
-- Peter
