[GRASSLIST:1635] Re: Error to compile r.in.gdal on MacX for grass 5.3
Glynn Clements glynn.clements at virgin.net
Sat Nov 1 01:00:16 EST 2003
Giacomo wrote:
> Hy, I'm still trying to install r.in.gdal in GRASS 5.3 on MacX, even if
> I've done some progress.
> I really need r.in.gdal in order to import quickly USGS SDTS DEMs.
For MacOSX, use the --with-gdal configure switch; that forces
r.in.gdal to link directly against the GDAL library (without it,
r.in.gdal loads libgdal dynamically using dlopen(), like a plug-in;
that doesn't work on MacOSX).
Glynn Clements <glynn.clements at virgin.net>
