[GRASSLIST:1702] i.ortho.photo
Ian Macmillan
ian_macmillan at umail.ucsb.edu
Thu Nov 6 22:27:17 EST 2003
Hi all, thanks for the previous info about ps.map, bummer about integers being
required for grid in latlong. New question for you.
I am using Grass 5.0.0 (openOSX) on a mac. I am trying to orhtorectify an air
photo, and am having bad luck. I have posted the rectified air photo here
(only 10 m resolution)
www.uweb.ucsb.edu/~ian_macmillan/calico.tif
No matter what I try, i seem to always get something like this. My GCPs have an
RMS of ~3.25 (meters). I am trying to follow the intstructions from the GRASS
book (neteler and mitasova), and everything looks right. I am using a DEM from
SRTM (30m resolution) that I have downsampled to 10m res. with r.to.sites and
s.surf.rst (the DEM looks reasonable). I am not sure if this resolution is
appropriate, but I am only trying to rectify the image right now at 10m
resolution. I am using a black and white orthophoto in my target location as
my base map. The relevant info from various steps (4,5,6,7) is at the end of
this email. It is kind of long, sorry, but I am pretty lost as to what is
happening. Anybody have any experience with this?
Thanks, ian
4)
Camera Name DBA________________
Camera Identification ___________________
Calibrated Focal Length mm. 152.772____________
Point of Symmetry: X-coordinate mm. 0__________________
Point of Symmetry: Y-coordinate mm. 0__________________
Maximum number of fiducial or reseau marks 8__________________
Fid# Fid Id Xf Yf
1 1_____ -113.2____ 113.2_____
2 2_____ 0_________ 113.2_____
3 3_____ 113.2_____ 113.2_____
4 4_____ 113.2_____ 0_________
5 5_____ 113.2_____ -113.2____
6 6_____ 0_________ -113.2____
7 7_____ -113.2____ -113.2____
8 8_____ -113.2____ 0_________
5)
Analysis of control point registration
error image photo
# col row target east north X Y
1 0.4 -2.6 0.1 126.1 9109.6 -113.2 113.2
2 0.9 2.0 0.1 4577.4 9095.4 0.0 113.2
3 -1.6 -2.8 0.1 9031.6 9090.6 113.2 113.2
4 0.6 3.5 0.1 9023.0 4628.2 113.2 0.0
5 1.3 1.1 0.0 9015.9 174.4 113.2 -113.2
6 -1.5 -5.5 0.1 4566.9 190.7 0.0 -113.2
7 not used 112.4 194.3 0.0 -113.2
8 -0.0 1.1 0.0 113.6 193.7 -113.2 -113.2
9 -0.1 3.3 0.1 120.1 4647.5 -113.2 0.0
Overall rms error: 0.08
6)
Initial Camera Exposure X-coordinate Meters: 514717________
Initial Camera Exposure Y-coordinate Meters: 3866713_______
Initial Camera Exposure Z-coordinate Meters: 4145__________
Initial Camera Omega (roll) degrees: 0_____________
Initial Camera Phi (pitch) degrees: 0_____________
Initial Camera Kappa (yaw) degrees: 0_____________
(**my initial air photo has north pointed up)
Apriori standard deviation X-coordinate Meters: 10____________
Apriori standard deviation Y-coordinate Meters: 10____________
Apriori standard deviation Z-coordinate Meters: 10____________
Apriori standard deviation Omega (roll) degrees: 0.01003_______
Apriori standard deviation Phi (pitch) degrees: 0.01003_______
Apriori standard deviation Kappa (yaw) degrees: 0.01003_______
Use these values at run time? (1=yes, 0=no) 0_
7)
error image target
# east north target east north east north
elev.
1 not used 3312.6 1427.0 513840.9 3864259.6 604.0
2 not used 866.7 4336.1 512055.2 3866421.3 647.4
3 1.0 -2.3 2.5 6783.3 390.0 516395.8 3863541.5 591.0
4 -0.4 -4.4 4.4 8454.5 2058.2 517533.8 3864874.4 748.3
5 not used 8662.5 4246.4 517442.4 3866481.9 1062.8
6 not used 5848.1 4769.8 515619.6 3866818.0 828.9
7 0.4 0.6 0.8 6547.4 6410.6 516094.0 3867961.3 840.3
8 -2.2 -5.4 5.8 3614.0 6347.0 514043.8 3867910.8 827.7
9 -1.4 -1.7 2.2 3078.6 4300.4 513648.5 3866465.0 729.0
10 -1.7 -5.2 5.5 4801.5 6911.4 514871.4 3868298.9 859.6
11 -1.6 0.5 1.6 1248.8 8418.5 512466.5 3869245.7 965.0
12 0.9 3.5 3.6 5945.3 3001.0 515685.2 3865573.4 868.2
13 -3.2 1.2 3.5 1243.4 6680.9 512424.2 3868103.1 892.5
14 0.9 0.1 0.9 6987.7 8096.7 516392.1 3869138.6 834.8
15 1.9 2.2 2.9 4380.9 5234.5 514578.6 3867136.4 746.1
16 -0.5 2.5 2.5 7315.8 3269.6 516625.2 3865777.7 910.5
17 -1.5 3.1 3.4 7321.4 3253.1 516633.0 3865764.2 904.4
18 not used 3319.5 1412.7 513804.0 3864293.6 605.4
19 2.0 1.6 2.6 1057.2 4457.1 512150.4 3866561.6 652.1
20 0.9 3.2 3.4 5944.9 3001.1 515685.2 3865573.3 866.9
21 0.2 0.4 0.5 4387.2 2743.4 514592.4 3865322.7 662.5
22 2.5 -2.4 3.5 7601.7 5775.6 516814.6 3867519.1 883.0
23 1.1 3.1 3.3 5944.1 3000.3 515684.5 3865572.9 866.9
24 -0.9 2.3 2.5 4388.4 2745.9 514594.4 3865322.7 662.5
25 not used 3318.6 1412.6 513803.9 3864294.4 604.8
26 2.2 -3.3 3.9 7601.5 5774.8 516814.8 3867519.4 883.0
Overall rms error: 3.26
