[GRASSLIST:1741] RE: Rdbi.PgSQL
Miha STAUT
mihastaut at hotmail.com
Mon Nov 10 05:13:21 EST 2003
You are lucky: I fixed it (with help of Steno Fontanari and Dirk
Eddelbuettel)). There is a "new" Rdbi on BioConductor.org, but they didn't
use our fixes and introduced two new bugs :-)
Here are temporarily the new packages containing all fixes:
http://mpa.itc.it/markus/tmp/rdbi/
For me it works fine now (maybe more fixes are needed).
Hope that they will pick up the fixes this times...
Cheers
Markus Neteler
I did as you said (loaded the new Rdbi and Rdbi.PgSQL packages) and tried it
out. The import into R commands worked alredy before. Now I managed without
problem to export into PostgreSQL a whole table, but exporting just a column
remains a problem.
dbAppendTable(conn,"drk",krevs)
#drk is an existing table and krevs is a column in it. krevs is also an
integer vector object in R. The result:
NOTICE: current transaction is aborted, queries ignored until end of
transaction block
At least now the command does not erase the table in PostgreSQL.
Only after thet I saw that I have to replace the code with the bugfixes
provided (or am I wrong?). For a while I looked stupid at the code and the
bugfixes after what I decided I should better wait for somebody to fix the
code and put it on the internet.
Thanks fot everything, Miha Staut
I did not understand whether I have to replace the code in the downloaded
packages with the bugfixes provided manualy or is that alredy done. In the
first case I think I will
Thanks, Miha Staut
_________________________________________________________________
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
