[GRASSLIST:1767] Re: realtime_gps
Maliheh
malihehs at yahoo.com
Sat Nov 15 07:18:34 EST 2003
> $USER_PROJ is the projection parameters used by
> PROJ.4's cs2cs.
> (i.e. everything after the +to)
> That is the projection parameters for your current
> location.
> You might look at g.projinfo for some ideas.
Thank you so much Hamish for your help.
but in grass5.7 when I use g.projinfo it shows:
can't read "opttype(1)":no such element in array
Now what should I do?
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
