[GRASSLIST:1768] Re: realtime_gps
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sat Nov 15 09:46:52 EST 2003
Hello
On Sat, 15 Nov 2003, Maliheh wrote:
> Thank you so much Hamish for your help.
> but in grass5.7 when I use g.projinfo it shows:
> can't read "opttype(1)":no such element in array
> Now what should I do?
Don't use g.projinfo in 5.7; use the newer g.proj. Specifically,
"g.proj -jf" will give you the projection parameters for your current
location in PROJ.4 format. Type "g.proj help" to see the other options
(there is no man page yet).
Paul
