[GRASSLIST:1882] Re: mysql,pg drivers for 5.7
Christopher Fonnesbeck
chris at fonnesbeck.org
Tue Nov 25 09:10:02 EST 2003
Yes, I was using Markus' binary, which based on the configure script he
pointed me to was not compiled with either database driver. I am trying
to compile it myself now.
C.
On Nov 25, 2003, at 8:59 AM, David Orme wrote:
> Are you using the binary version provided for Mac OS X by Markus
> Neteler? I've downloaded the same thing and it works fine (Thanks,
> Markus) but has the same limited set of drivers (dbf, shp) - I've been
> assuming that the binary was built without postgres, mysql and odbc
> support in order to reduce the set of dependencies and make the binary
> more portable. If this isn't the case, I'd like to work out how to get
> pgsql and odbc too but I suspect I need to configure and build my own
> copy if I want a postgresql and ODBC support.
> David
> On Tuesday, November 25, 2003, at 12:12 am, Christopher Fonnesbeck
> wrote:
>> I am trying to use either mysql or postgresql to store attributes for
>> a GRASS database I am building in GRASS 5.7 (since 5.0.2 does not
>> work reliably with postgresql). Unfortunately when I try and manage
>> the default settings using v.database as outlined in the tutorial,
>> the only drivers are dbf and shp (since when is shapefile a database
>> driver??). Nowhere does it say where to get the pg/mysql drivers, so
>> I would be most appreicative of anyone who would point me in the
>> right direction. It might be a good idea to include these in future >
>> releases.
>> Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
>> Georgia Cooperative Fish & Wildlife Research Unit, University of
>> Georgia
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
