[GRASSLIST:1888] Re: URGENT - GRASS shuts down with no reason
James Dasher
misterdasher at mac.com
Wed Nov 26 07:49:39 EST 2003
On Tuesday, Nov 25, 2003, at 08:38 US/Eastern, Carlos Henrique Grohmann
wrote:
> All,
> I'm with a strange problem here in GRASS 5.0.3. when I start it, and
> select my
> location, the gui opens, but, on the command line, the program exits
> automatically. now I can't use GRASS.
I'll tell you what worked for me, though I make no guarantees it'll
work for you.
I deleted the .grass5rc file from my home directory. That caused GRASS
to re-write the file. You'll have to go through the setup - location
of your data, and so forth - but it'll work.
Make sure to save your old .grass5rc file - "cp .grass5rc .grass5rc.bk"
or something similar. If you don't mind editing the .*rc file, you
might just have something corrupted.
Otherwise, check your error logs. Recent messages to the list have
discussed how to do this.
Good luck -
PS I've only started using (read: learning) GRASS myself, so my
suggestion may not apply. Or, I could be cracking walnuts with a
sledgehammer. :)
