[GRASSLIST:1409] Re: import AVHRR.
Alip.Yasin s01k154 at shako.sk.tsukuba.ac.jp
Sun Oct 5 13:37:46 EDT 2003
Dear Andrey Kiselev
I tried <gdalinfo --formats> and I have GDAL supported file name <L1B: NOAA
Polar Orbiter Level 1b Data Set> listed there.
But still r.in.gdal gives me "not supported file" error.
I will try to use Bugzilla to report this problem.
Thank you all for your help to me.
Thank you a lot.
Sincerely
Ghalip Yasin
Tsukuba University,Japan
  On Sat, Oct 04, 2003 at 04:54:03PM +0900, Alip.Yasin wrote:
  > Thank you too much.
  > I tried command r.in.gdal input=A3164585.L4908097 output=name, but it
said:
  > ERROR4: 'A3164585.L4908097' not recognised as a supported file format.
  Looks like you have outdated GDAL. Please, run `gdalinfo --formats'
  command and check whether the output contains a line for
  `L1B: NOAA Polar Orbiter Level 1b Data Set'. If so and you still get an
  error when reading your dataset, you should report this problem
  via Bugzilla
   http://bugzilla.remotesensing.org/enter_bug.cgi?product=GDAL
  Andrey V. Kiselev
  Home phone:  +7 812 5274898  ICQ# 26871517
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20031006/cb85a691/attachment.html
