[GRASSLIST:1412] Re: import AVHRR.
    Markus Neteler
    neteler at itc.it
    Mon Oct  6 09:48:39 EDT 2003
On Mon, Oct 06, 2003 at 02:37:46AM +0900, Alip.Yasin wrote:
> Dear Andrey Kiselev
> I tried <gdalinfo --formats> and I have GDAL supported file name <L1B: NOAA
> Polar Orbiter Level 1b Data Set> listed there.
> But still r.in.gdal gives me "not supported file" error.
> I will try to use Bugzilla to report this problem.
There is probably a local copy of libgdal within your GRASS installation
which is used by r.in.gdal instead of the system-wide installed library.
Markus
> Thank you all for your help to me.
> Thank you a lot.
> Sincerely
> Ghalip Yasin
> Tsukuba University,Japan
>   On Sat, Oct 04, 2003 at 04:54:03PM +0900, Alip.Yasin wrote:
>   > Thank you too much.
>   > I tried command r.in.gdal input=A3164585.L4908097 output=name, but it
> said:
>   > ERROR4: 'A3164585.L4908097' not recognised as a supported file format.
>   Looks like you have outdated GDAL. Please, run `gdalinfo --formats'
>   command and check whether the output contains a line for
>   `L1B: NOAA Polar Orbiter Level 1b Data Set'. If so and you still get an
>   error when reading your dataset, you should report this problem
>   via Bugzilla
>    http://bugzilla.remotesensing.org/enter_bug.cgi?product=GDAL
>   Andrey V. Kiselev
>   Home phone:  +7 812 5274898  ICQ# 26871517
