[GRASSLIST:1458] Re: GRASS on OSX -
    Glynn Clements
    glynn.clements at virgin.net
    Thu Oct  9 08:45:58 EDT 2003
Hugh Evans wrote:
> Examples of other errors:
> GRASS 5.0.2 > NavGetReply failed, -128 xterm Xt error: Can't open
> display:
> GRASS 5.0.2 > tcltkgrass & [2] 2774
> GRASS 5.0.2 > xterm Xt error: Can't open display:
1. Ensure that the X server is actually running.
2. Ensure that the environment variable DISPLAY is set appropriately.
For a Bourne shell (bash, ksh etc), use:
	DISPLAY=:0
	export DISPLAY
For a C shell (csh, tcsh), use:
	setenv DISPLAY :0
If you start the X server as part of a session (e.g. using startx),
any terminals (xterm) which were created as part of the session should
already have DISPLAY set appropriately. OTOH, if you start the X
server directly, you have to set DISPLAY manually.
Glynn Clements <glynn.clements at virgin.net>
