[GRASSLIST:1464] Re: Maiking GRID
Hamish
hamish_nospam at yahoo.com
Fri Oct 10 04:43:16 EDT 2003
> I have got a raster image. The image has latitudes and
> longitudes marked as vertical and horizontal lines
> with a difference of 4 degrees. I want to palce a grid
> of 1 degree x 1 degree in ecah 4 degree x 4 degree
> grid. So that the resultant map has latitudes and
> longitudes with a grid resolution of 1 degree x 1
> degree.
d.grid? If it is a projected location maybe you have to do some
size=(cos)latitude/(60*1852) origin=+x,+y math by hand. (->wish?)
[Paul: a practical use for GRASS 5.3's m.proj2 [-i|-o]! Help find the
offset in meters from nearest confluence ;)]
Hamish
