[GRASSLIST:1474] Re: r.in.gdal segmentation fault!
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Oct 13 07:11:09 EDT 2003
On Mon, 13 Oct 2003, Zbigniew Perski wrote:
> At home I have compilled GRASS from sources and the situation is the same.
> I know that this problem was already on the list but as I know there was
> no doresct solution.
There was a correct solution: compile GRASS using the --with-gdal configure
option.
