[GRASSLIST:1476] Re: r.in.gdal segmentation fault!
Vincent Schut
schut at sarvision.com
Mon Oct 13 07:31:19 EDT 2003
On Mon, 13 Oct 2003 12:54:17 +0200
Zbigniew Perski <perski at us.edu.pl> wrote:
> Hi,
> I am new on the list but I am successfuly using GRASS since some months.
> Currently I have re-instaled system and I am using debian installed via
> knoppix.
> I have two computers at work and at home. At work I have installed thae
> latest gdal (from deb packages) and grass from binary flies. And when I
> am trying to use r.in.gdal I am allways receiving
> segmentation fault.
> I have tried to work around by copying libgdal.1.1.so to /usr/lib/ and
> /usr/lib/grass5/lib but is is stil not working.
> N.b. gdal is working without a problem!
> At home I have compilled GRASS from sources and the situation is the same.
> I know that this problem was already on the list but as I know there was
> no doresct solution.
> Maybe someone can help me?!!!
You might want to check if there is accidentally more than one copy of libgdal on your system, e.g. one in /usr/lib and one in /usr/local/lib. This might cause grass use the api from one and trying to link to the other, resulting in problems.
Cheers,
Vincent.
> Regards
> Zbigniew
> dr Zbigniew Perski
> Geological Visualization Laboratory
> Department of Fundamental Geology
> Faculty of Earth Sciences at UNIVERSITY OF SILESIA
> Bedzinska 60, 41-200 Sosnowiec
> POLAND
> fax: +48 32 2915865
> phone: +48322918381 e.420
> http://kgp.wnoz.us.edu.pl/insar
