[GRASSLIST:1479] Re: r.in.gdal segmentation fault!
Zbigniew Perski perski at us.edu.pl
Mon Oct 13 08:12:14 EDT 2003
> You might want to check if there is accidentally more than one copy of libgdal on your system, e.g. one in /usr/lib and one in /usr/local/lib.  This might cause grass use the api from one and trying to link to the other, resulting in problems.
Thanks for advice.
I have just checked it but the problem still remains .... I will try wit
recompilation.
regards
Zbigniew
