[GRASSLIST:1617] Re: m.in.e00 woes
Markus Neteler
neteler at itc.it
Fri Oct 31 04:55:22 EST 2003
On Thu, Oct 30, 2003 at 05:23:32PM -0800, Ian Macmillan wrote:
> Hi all, I am trying to import a .e00 file with m.in.e00, and it is taking
> FOREVER. So far we are on hour eight of processor time on a dual 1 GHz G4
> powermac running GRASS 5.0.0. The original .e00 file was only 35 Mb. The file
> contains a series of points, with several attributes. All i want are the
> locations of the points (essentially a simple site file without any
> categories). The file should have ~150,000 sites. Is there a way to speed up
> this process? This is taking way too long. I hope to be able to import
> several more files like this, but not if it takes over 8 hours per file. Any
> advice would be helpful.
You could try this
AVCIMPORT - Version 1.2.0 (2000-10-17)
Convert an Arc/Info vector coverage from E00 to binary.
Copyright (c) 1999, 2000, Daniel Morissette (danmo at videotron.ca)
AVCE00 web page: http://pages.infinit.net/danmo/e00/
Usage: avcimport <input_file> <coverage_path> [<coverage_type>]
<coverage_type> is either 'V7' (the default) to write a Unix V7.x coverage,
or 'PC' to write a PC/Arc coverage.
and the ogr2ogr to make it a different format.
Markus
