[GRASSLIST:1619] Installing grass57_exp_2003_10_25 on MacX
Giacomo
giacomo.bertoldi at ing.unitn.it
Fri Oct 31 04:20:45 EST 2003
I've tried to install grass 5.7 on MacX:
the make command gives the following error:
gcc -L/sw/lib -L/sources/grass57_exp_2003_10_25/dist./lib
-dynamiclib -Wl,-flat_namespace,-U,_cuserid -L/sw/lib
-L/sources/grass57_exp_2003_10_25/dist./lib \
OBJ./get_proj.o OBJ./do_proj.o OBJ./convert.o OBJ./datum.o
OBJ./ellipse.o -lgrass_gis -lgrass_datetime -lintl -lproj -o
/sources/grass57_exp_2003_10_25/dist./lib/libgrass_gproj.dylib
ld: Undefined symbols:
_OSRDestroySpatialReference
_OSRExportToPrettyWkt
_OSRExportToWkt
_OSRGetAttrValue
_OSRImportFromProj4
_OSRMorphToESRI
_OSRNewSpatialReference
/usr/bin/libtool: internal link edit command failed
make[2]: ***
[/sources/grass57_exp_2003_10_25/dist./lib/libgrass_gproj.dylib] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
