[GRASSLIST:1621] Re: a problem in NVIZ
Glynn Clements glynn.clements at virgin.net
Fri Oct 31 05:00:44 EST 2003
temiz wrote:
> I am afraid I am not clear on:
> --with-motif-includes=/usr/X11R6/include \ # there is not such a directory.
> necessary include files may be in  /usr/X11R6/GL directory ?
> Are motif files necessary ? What are their function ?
> --with-glw: this usage is ok. no need to define any include or library directories ?
NVIZ doesn't require either Motif or GLw. Motif is only required by
xganim and r3.showdspf.openGL; GLw is only required by
r3.showdspf.openGL. Unless you need these programs, I suggest using:
	--without-glw --without-opengl
NVIZ does require both OpenGL and Tcl/Tk. Both of these are normally
found without needing any --with-*-includes= or --with-*-libs=
switches.
> I could not see REQUIREMENTS.html  file in the web page.
It is in the top-level directory of the GRASS source tree.
Glynn Clements <glynn.clements at virgin.net>
