[GRASSLIST:1630] Error to compile r.in.gdal on MacX for grass 5.3
Giacomo
giacomo.bertoldi at ing.unitn.it
Fri Oct 31 18:15:51 EST 2003
Hy, I'm still trying to install r.in.gdal in GRASS 5.3 on MacX, even if
I've done some progress.
I really need r.in.gdal in order to import quickly USGS SDTS DEMs.
Now I'm able to install gdal from cvs using the useful tutorial "Grass
v.5.7 installation on Mac OS X" made by Fabrizio Zanotti
(fabrizio.zanotti at ing.unitn.it).
I've downloaded the current version of Gdal-cvs package
(gdal-cvs-YYMMDD.tar.gz ) from the gdal ftp site,
ftp://ftp.remotesensing.org/gdal/daily, and used a configuration script
like:
#!/bin/sh
# script to compile GDAL on Mac OSX
# Markus Neteler and Fabrizio Zanotti
# 10/2003
# what to do in case of user break:
function exitprocedure()
echo "User break!"
exit
# shell check for user break (signal list: trap -l)
#trap "exitprocedure" 2 3 15
#add for GRASS libgrass support:
export CPPFLAGS="-I/usr/local/pgsql/include/"
# libgrass support:
./configure --without-python \
--with-grass \
--with-libtiff=internal \
--with-geotiff=internal \
--with-libtool \
--with-pg-includes=/usr/local/pgsql/include
In this way is possible to install gdal.
If I configure grass with the option:
--with-gdal=/usr/local/bin/gdal-config
we have support gdal=yes,
but if I do make there is an error
GRASS GIS compilation log
Start of compilation: Fri Oct 31 14:42:35 PST 2003
Errors:
Compilation error in module: src/raster/r.in.gdal (ignored)
Also if I try to install only the gdal module with gmake5 i have the
error:
bash-2.05a$ gmake5
SRC = /sources/grass53_exp_2003_10_25/src
CMD = /sources/grass53_exp_2003_10_25/src/CMD
UNUSED = /sources/grass53_exp_2003_10_25/unused
HEADER = head.unknown
ARCH = unknown
GISBASE = /sources/grass53_exp_2003_10_25/dist.unknown
VERSION = 5.3-cvs 2003
/sources/grass53_exp_2003_10_25/src/raster/r.in.gdal
make -f OBJ.unknown/make.rule
gcc -L/sources/grass53_exp_2003_10_25/src/libes/LIB.unknown -L/sw/lib
-o /sources/grass53_exp_2003_10_25/dist.unknown/etc/bin/cmd/r.in.gdal
OBJ.unknown/main.o OBJ.unknown/gbgetsymbol.o OBJ.unknown/gdalbridge.o \
-L/usr/local/lib -lgdal -lgproj -lproj -lgis -lintl -lI -lz
ld: Undefined symbols:
_GBGetSymbol
make: ***
[/sources/grass53_exp_2003_10_25/dist.unknown/etc/bin/cmd/r.in.gdal]
Error 1
Somebody can help me?
Thanks, Giacomo
Giacomo Bertoldi
Ph.D. Student
University of Berkeley
