[GRASSLIST:1167] Re: r.mapcalc error
Bill Dickinson Jr
wdickins at pop700.gsfc.nasa.gov
Wed Sep 10 09:33:24 EDT 2003
Thanks for the tips, Hamish. ;-) I've checked my install of readline
(through Fink) and it is already at 4.3-5. Unless OS X has it's own,
earlier version of readline that is superseeding the Fink readline, I
don't think this is the problem. However, I have downloaded the
readline 4.4.7 source and may also try using that instead of 4.3-5.
If that doesn't work, then I will recompile using --with-readline as
you suggest and see what happens.
Bill
> > Anybody run across this error?
>> GRASS 5.0.2 > r.mapcalc
>> dyld: r.mapcalc version mismatch for library:
>> /usr/local/lib/libreadline.4.dylib (compatibility version of user:
>> 4.2.0 greater than library's version: 4.0.0)
>> Trace/BPT trap
>Some hints & guesses:
>".dylib" means it is a Mac OS/X Dynamic Library & thus a OS/X specific
>problem. It seems r.mapcalc was compiled with readline 4.2.0 headers
>while the main system libary for readline on your computer is only 4.0.0.
>You might have two versions on you computer, but I'd guess you are
>trying to use binaries compiled on someone elses (more up to date) OS/X
>system.
>Binary install:
>Try updating the system's realine libraries (fink?) to 4.2.0.
>Source install:
>Try compiling without the --with-readline ./configure option, it
>isn't critical, I think.
>Hamish
>disclaimer: I have no idea.
Bill Dickinson
GIS Specialist
NASA Goddard Space Flight Center
Environmental & Safety Branch, Code 250
