[GRASSLIST:1180] Re: Recompiling
Glynn Clements glynn.clements at virgin.net
Wed Sep 10 15:14:02 EDT 2003
Bill Dickinson Jr wrote:
> > Source install:
> > Try compiling without the --with-readline ./configure option, it
> > isn't critical, I think.
> Are there any pitfalls when recompiling GRASS? Do I simply run the
> configure/make/make install again? Does this overwrite the current
> installation or do I have to clean out the current installation
> before recompiling?
If you re-run configure, run "make distclean" before recompiling.
"make install" should just overwrite any existing installation,
although it's probably worth removing the old installation prior to
running "make install" just to be safe.
Glynn Clements <glynn.clements at virgin.net>
