[GRASSLIST:1181] Re: Recompiling
Glynn Clements
glynn.clements at virgin.net
Wed Sep 10 19:51:14 EDT 2003
Glynn Clements wrote:
> > > Source install:
> > > Try compiling without the --with-readline ./configure option, it
> > > isn't critical, I think.
> > Are there any pitfalls when recompiling GRASS? Do I simply run the
> > configure/make/make install again? Does this overwrite the current
> > installation or do I have to clean out the current installation
> > before recompiling?
> If you re-run configure, run "make distclean" before recompiling.
Clarification: run "make distclean" before re-running configure, as
"make distclean" deletes the files which configure creates. IOW, if
you intend change the configure options, start from scratch.
Glynn Clements <glynn.clements at virgin.net>
